Old 06-09-2010, 12:05 AM   #1
2.5RHDsupra
2.5RHDsupra's Avatar
2.5RHDsupra is on a distinguished road
Default Blow off Valves
I got an Automatic supra, is there a good reason to put blow off valves on it, what benefits would i be getting from installing them.
2.5RHDsupra is offline   Reply With Quote
Old 06-09-2010, 04:00 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
BOV and BPV protect against compressor surge as the throttle plate is closed. With an auto, the throttle plate is typically closed less frequently than with a std transmission. However, there are still times that the driver may close the throttle plate abruptly while building boost. This scenario would benefit from having a BOV or BPV installed (correctly) on the vehicle.
Old 06-09-2010, 04:38 AM   #3
2.5RHDsupra
Ok so what do you think is a good price for a blow off valve?
Old 06-09-2010, 07:31 AM   #4
btwilson86
Super Moderator
btwilson86's Avatar
Haha.... THAT I am not sure of. I didn't have a turbo car long enough to start looking for replacement ones. IMO, a "good price" is relative to the purchaser. If you think it's a good price for what you're looking for in a BOV, type the part number into your search engine and see what people are selling one for. I am sure you'll find a deal you can't pass up.
The following is a short list of a few things to look for in a BOV:
Get a piston type valve, they are not as likely to bleed as you build boost. Less bleeding=quicker acceleration/more power, plus the "Whooosssssssh" sound is much more pronounced.
BUY NAME BRAND! Alot of the cheaper "replica" valves have springs that are too tight or too weak, leading to a late release (more compressor surge) or early release (top end boost leak).
Read the reviews, ask questions. If it's a decent BOV, people will have already tried it. See what they thought. Also, a good BOV will usually have a good company behind it. Look at the specs, talk to the sales reps. Find out what makes that one better than the rest.
Intake Valves Clearance Adjustment question donkey MKIII Supra 1 09-14-2009 02:45 AM
Some good info on Blow off valves mkiiisupra MKIII Supra 2 01-11-2008 02:13 PM
Valves, Cams,& the works carfanatic89 MKIII Supra 6 06-06-2007 04:02 AM
Do the MK3's have blow off valves? XKeyLocX MKIII Supra 5 01-30-2006 07:06 PM
Blow Off valves? lildawg720 MKIV Supra 9 06-13-2005 08:40 PM
