Old 09-15-2005, 10:14 PM   #1
pete2bram
pete2bram is on a distinguished road
Default Mk111 Heater Problem 'help'
All of a sudden the heater on my MK111 has stopped heating....air con is ok, cooling system is ok [new water pump recently fitted] and temp gauge keeps a perfect average. I know it could be an air lock but has anybody else out there had a similar problem and what's the best way to dissipate an air lock please. [also head gasket is ok]
Pete.
pete2bram is offline   Reply With Quote
Old 09-17-2005, 03:22 AM   #2
The water valve may gone into an 'off' mode. If the vacuum diaphram in it has a hole, it won't allow hot water to get to the core.
The vsv with it may be bad. Check to see if the valve works. By-pass the vsv with the vacuum hose hooked directly to the heater water valve. (its on the firewall, heater water hoses hook into it).
The vsv goes bad with age. I just removed mine, and run vacuum to the water valve in the fall/winter/early spring. Then I remove it and plug a golf tee into the vacuum line for the late spring/summer.
Old 10-05-2005, 09:15 PM   #3
blitzmkiii
blitzmkiii is on a distinguished road
my heater went out to leaks anti freeze in the floor board mines the heater core
blitzmkiii is offline   Reply With Quote
Heater problem! paulmicin MKIII Supra 6 07-19-2008 12:21 AM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
heater problem..... cold like heck... hangsupra MKIII Supra 9 01-28-2007 05:35 PM
Heater Problem octron Non-Generation Specific Questions 0 04-09-2006 07:32 PM
Heater Problem scruffboy Non-Generation Specific Questions 5 01-24-2006 11:42 PM
