#1 |
I have a 1989 Supra N/A and I was inspecting the exhaust system. I noticed that between the catalytic converter and the muffler at the rear there seems to be a second muffler. What is this and why is it there? Can it be removed? I would appreciate any info.
Thanks! |
#2 |
it is the resonator. if u take it out it will make your car louder. i took mine out and put a 2 1/2" catback exhaust of with a straight through muffler and it sounds awesome
91 N/A automatic supra;K&N FIPK;2.5" custom exhaust;no cat;pacesetter header;eibach springs;tokico "blues";MKIV TT rims |
#3 |
A resonator huh. OK, sounds useless. What exactly is a catback exhaust? thaks for the help
#4 |
SP58GT
it is pretty useless...its there to keep the car quiet...though i think you might need to put it back during state inspection...because i think in jersey ur required to have them
Now: Saving for an MKIV Broken Rides: (Sold) 91 supra turbo 5speed with a 1jzgte motor 421whp 400(399) ft*lbs of torque on tap @ 15 psi "Always outnumbered, never outgunned." |
#5 |
a catback exhaust is when u get new exhaust piping from the catalytic converter on back and a new muffler
don't they only check your car for emissions once in a lifetime
#6 |
I think in Jersey they check emissions every 2 yrs. I get inspected this December, so after that I will do some exhaust upgrades and be ready for the summer, ha ha. should I replace the cat with a performance job? My A-hole friend said he could clean my engine, but after he did it needed to be dried so he revved the engine to a point where I saw the cat get red hot. I mean it turned red. Do you think that ruined it. (I will never let this person near my car again) I got everything back in order and it runs great again idling at about 800 and taching out at about 3500. Any suggestions on exhaust upgrades. If you install a header do you keep that heat shield on? Thanks in advance.
James (scruffboy) |
Thread Tools | |
Display Modes | |
Exhaust System | SideWinderGX | MKIII Supra | 8 | 02-28-2007 08:01 AM |
i was thinkin side exit exhaust system for my 87 supra.... | the t3d | MKIII Supra | 11 | 10-05-2006 05:02 PM |
BLITZ Nur Spec Racing Series Cat-Back Exhaust System??? | HeadofaHessian | MKIII Supra | 0 | 11-10-2005 05:24 AM |
exhaust system | kewlcoconut | MKIII Supra | 10 | 11-02-2005 07:46 PM |
