Old 10-05-2005, 03:13 AM   #1
BlueSupra865
BlueSupra865 is on a distinguished road
Default Head Erosion Behind #6
I have the head off of my 86.5 supra. While examining the head I found erosion in the surface just behind the #6 combustion chamber. At first I thought that it was a clogged water port, but on cleaning it appears to be metal that has been eroded. I though that it was a water port because it's above a water port in the block and the head gasket has a water port in the same location.
Is this a feature of the supra block and head that they do not have matching water ports behind #6? Is the head supposed to have a water port in that location? Has anyone else experienced this and found a good solution?
Thanks.
BlueSupra865 is offline   Reply With Quote
Old 10-05-2005, 07:56 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
if there is pitting in the block i would see how deep it is and if your machine shop can machine it down to get them out
what power are you going for? that's a big thing in deciding what you will do with this block
and yep it's common to have mismatched cooling jackets on block & hg
some random toyota thing lol
Pics of my build.
Do a diagnostic first!
Old 10-06-2005, 02:40 AM   #3
BlueSupra865
The erosion is in the head. A pocket about 1/8" deep 1/4" wide and just less than an inch long. A collegue recommended JB Weld to fill the pocket then file to match the head surface. Has anyone had expeience with an approach like this? If so, did it work?
Old 10-06-2005, 11:08 AM   #4
ddmcse
ddmcse's Avatar
Cool
just on the head none on the block ?
http://www.ddmcse.com/turbo/bhg_2003.htm
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 10-06-2005, 11:49 AM   #5
suprra_girl
7M POWAH! ;)
^ that block is after it was machined
that's friggin terrible
here's my block after machining (sorry 56kers)
[img]www.supra.co.nz/IMAG0025.JPG[/img]
i would assume my hg will seal hehe
so ya let me know if that is after it was machined
Pics of my build.
N20 and HeAd WoRk Supra_87_mk3 Non-Generation Specific Questions 4 05-25-2007 03:09 PM
head gas kit problem sevenmgte MKIII Supra 3 03-29-2006 01:53 AM
Head Gasket Part II Bullz_EyE MKIII Supra 2 01-26-2006 06:30 PM
