Old 10-27-2005, 02:46 AM   #1
lilman87
lilman87's Avatar
lilman87 is on a distinguished road
Default no air or heat....help!
on my 87' supra the air conditioning doesnt get cold enough to do anything in the summer and also the heat doesnt get hot in the winter. does anyone have any idea what might be causing this problem? i'm geting worried, in the summer i could just roll the windows down, but now in the winter i might be in trouble! lol
lilman87 is offline   Reply With Quote
Old 10-27-2005, 01:55 PM   #2
supra_91
supra_91's Avatar
for the heater....replace the thermostat
as for the air conditioner....you might be low on freon
Old 10-27-2005, 08:38 PM   #3
lilman87
lilman87's Avatar
i was thinkin about changine the thermostate anyway so that will be good if it helps the heater. when i bought the car the guy said that there was a hole in one of the a/c lines so how would i go about testing that. that would probly be the reason that i would be low on freon.
Old 10-28-2005, 12:13 AM   #4
supra_91
supra_91's Avatar
find the line with the hole in it and replace it
Old 10-28-2005, 03:33 AM   #5
lilman87
lilman87's Avatar
anysugestions on how to find the line with the hole in it?
Old 10-28-2005, 12:28 PM   #6
ddmcse
ddmcse's Avatar
Cool
your heater problem is a broken valve that can be by-passed . i forget the details right now . the valve is passenger side (U.S) on the firewall it's one little swap of tubes and you'll get heat . research online you'll find it.
it's a vac switch and with no switch there's no hot water flowing into the heater core
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 10-29-2005, 07:16 AM   #7
mrnickleye
mrnickleye's Avatar
Wink
A/C...if its still R12 freon, you probably can't get any from a parts house. You will probably need to take it to a shop. They can check out the system for about $50 (my shops price).
Heater...while engine is running, just unplug the vacuum line from the engine, going to the VSV (wires to it) by the heater water valve, then plug it into the heater valve. Valve should work, you'll see it move. Normal operation is that water always flows thru the heater core, except when the temp controls are set to 65*.
Old 10-31-2005, 02:20 AM   #8
lilman87
lilman87's Avatar
awsome...thanks guys i will get to workin on it and let ya know. then again who knows when that will be but it will happen.
Old 11-02-2005, 04:03 AM   #9
1988gte
1988gte is on a distinguished road
Any pictures on this process?
1988gte is offline   Reply With Quote
Old 11-03-2005, 04:42 AM   #10
mrnickleye
mrnickleye's Avatar
No pictures. The valve is on the passenger side firewall` up high. 2 heater hoses go into it.
87 MK III turbo - AC & Heat Always On Problem robfab MKII Supra 0 08-04-2008 07:12 PM
Heat Consistancy Issues Chambers MKIII Supra 14 04-07-2008 12:52 AM
IC pipes and heat wrap questions. redmaro MKIII Supra 0 09-26-2007 08:00 AM
Heat?? burton51m MKIII Supra 11 02-25-2007 04:28 PM
heat getting into car sd88supra MKIII Supra 7 11-03-2006 12:47 AM
