Old 01-04-2005, 02:47 AM   #1
tim kramarenko
Guest
Posts: n/a
what kind of turbo is better for my 97 supra the t66 ball bearing or just regular turbo....wut is the diffrence bettweeen them
Old 01-15-2005, 02:05 AM   #2
Keith
Guest
Posts: n/a
Well it depends on what you want.
Old 01-15-2005, 02:08 AM   #3
Guest
Guest
Posts: n/a
From what I understand. That ballbearing is goona be more reilable and last longer. Spool up time will be zilch. Almost like a super charger.
The T66 will give you more hp on your top end and generally will create more hp once you get into high RPMs.
Old 01-15-2005, 05:07 AM   #4
the_fallen
the_fallen is on a distinguished road
ball bearing turbo's are no more reliable or last longer than standard turbo's. spool time will be considerably less, but a turbo of that size will still take a little while to spool. also ball bearing turbo's are hell expensive to rebuild, if they can rebuild them. other than that, ball bearing and normal are the same. basic differences are cost of rebuild vs spool time.
the_fallen is offline   Reply With Quote
Old 01-25-2005, 01:16 AM   #5
JayMark
Guest
Posts: n/a
I'd go for the T66. Yes it lags compared to stock ones but it's all about driving skills. If you are skilled enough, the lag won't affect your performances at all (well, not much). I've already had a ride in a big turbo supra (much bigger than the T66) and god, it pulled. Even from a stop, he could take off like a bat out of hell even if he hit full boost at around 5000RPM. Like I said, it's all about skills.
Plus, if the turbo kicks in at high RPMs, well it means that on regular driving on low RPMs, the car will act like stock and not drink much more fuel.
And it depends on what you want. If you want a top end crusher that's gonna pull and pull go for the T66. If you are interested, I even know a company that sell theire own innovative turbos (very good and robust turbos) and they got one witch spools only a hair later than the T66 (like only a couple hundreads more RPM) but gives you 300+ more HP and tons more torque than the T66. And one supra that has this exact turbo even runs in the 9's on the quarter mile so talk about lag... actually, this supra is the fastest street supra in the world at the track. How come? Well, my friend, it's all about driving skills and the owner of the supra explain this on his site.
Lag isn't that much of a problem if you know how to deal with it.
The site is www.wotm.com
Upgrading turbos on a 1jz supradaddy0803 MKIII Supra 1 07-16-2007 10:08 PM
TURBO's Anyone? Luvs2slide MKIII Supra 0 08-16-2006 03:28 AM
Twin TD07-25G "T-67" Turbos on a 1JZ or 2JZ *pics* kingtal0n MKIV Supra 1 03-20-2006 02:36 PM
replaceing turbos (ct12's)....need help.... sexy91tt MKIII Supra 0 02-10-2006 10:35 PM
