Old 02-12-2005, 06:52 AM   #11
check the fusebox in your engine bay, particularly change AM2 AM1 and the main silver round one and also check your EFI Fuse.... if these all check out fine then go to a junkyard and get another ignitor and try that
let us know how you get on
Old 02-12-2005, 11:43 PM   #12
snafu54
snafu54 is on a distinguished road
checked the fuses and they check out. the junk yard dosent have any igniters and they are way too exspencive for me to buy one 300-500$ im trying to get a job. is their any other toyotas i can get an igniter from that will work on my 87 supra non turbo.
snafu54 is offline   Reply With Quote
Old 02-15-2005, 11:37 PM   #13
snafu54
the igniter is good it almost started up i filled the tank i think the fule filter is bad.
Old 02-16-2005, 09:31 AM   #14
hey just a thought i had... have you checked your timing, make sure the belt is lined up with all the marks and also check the distributor... this can cause the car to crank but not fire
Old 02-22-2005, 05:16 AM   #15
snafu54
but i should get spark from the coil even if the timing is off.
Old 02-22-2005, 07:40 AM   #16
please explain the process you took in checking whether your car has spark or not
i.e. pulled lead off etc etc
Old 02-24-2005, 10:09 PM   #17
snafu54
i took the spark plug wire off the distributer cap that goes to the coil put the wire from the coil 1/4 inch away form the block and cranked it over and my friend said their was no spark. then i have tried taking out a spark plug put it 1/4 inch away from the block and still no spark.
Old 02-24-2005, 11:17 PM   #18
well it can be only one of two things
coil or ignitor or your am1 or am2 or other fuses are blown
check them over again and borrow someones coil & ignitor and try it out
good luck
Old 02-28-2005, 11:12 PM   #19
snafu54
no one has an igniter to let me borrow! am1 or am2 where are they located?
Old 02-28-2005, 11:18 PM   #20
they are located in the engine bay fusebox beside the battery
No fire no start...! lil help please 94GT47Widebody MKIV Supra 32 09-03-2009 03:20 PM
Loss of power and electrical fire mister MKIII Supra 0 12-16-2008 10:17 PM
Fire hattrick Non-Generation Specific Questions 1 03-18-2008 01:59 PM
my 1995 supra engine wont fire gkhawk Non-Generation Specific Questions 6 08-25-2006 09:58 PM
back fire intense 7MGTE MKIII Supra 3 09-26-2005 05:37 PM
