Old 11-24-2005, 04:50 PM   #1
sloweredk300e
sloweredk300e is on a distinguished road
Default Supra Newbie
I am purchasing a non turbo 1987 Supra.
I am doing a full off rebuild on whatever I buy. Since I have a body shop I am doing a custom paint job and fully custom interior.
What I need help with is the engine.
Does the '87 NA engine need to be completely rebuilt to handle a turbo?
Which, if any MKIV engines will fit?
Also what are some good sites for more Supra info?
Thanks
Kyle
I have done several engine swaps on BMWs so this is not new too me. Just gathering some knowledge.
sloweredk300e is offline   Reply With Quote
Old 11-25-2005, 01:04 AM   #2
WiseAssJester
WiseAssJester is on a distinguished road
No, the NA motor doesn't NEED to be rebuilt to handle a turbo.
Make sure you keep the air/fuel ratio at a stoichiometric(pardon the spelling) level.
And I'm going to drop a 2jz motor into a Supra, as soon as I find the appropriate car. From what I can tell, ECU and everything else aside, all it requires to physically get the motor under the hood is a new set of motor mounts.
WiseAssJester is offline   Reply With Quote
Old 11-25-2005, 04:26 PM   #3
SupraMan1784
SP58GT
jester you got the spelling right, though for the na motor to handle a turbo you dont necessarily need a rebuild if you plan on running stock psi...8-9, if you want big power and more psi...then u will def need it or risk blowing the motor
Now: Saving for an MKIV
Broken Rides:
Supra Newbie Questions Grandavi Non-Generation Specific Questions 9 09-02-2008 07:29 AM
Supra newbie questions. 72charger Non-Generation Specific Questions 4 07-30-2006 01:07 PM
Supra NEWBIE! kranke9 MKII Supra 5 12-05-2005 09:23 PM
newbie please help supra TT jason17 MKIV Supra 0 08-31-2005 04:51 AM
