#11 |
Thanks to everyone who responded, I've checked the pics, snaked a drop light into the comparment, took off grilles and turnsignals but still can't get this bi*ch open (the 15o weather here in Jersey ain't makin it easier. I made an appointment at body shop I know. When (if) he gets it open I am going to study it with a friggin microscope so this will never happen again. Also, I am going to study gas cap door cable in case something happens to that. I would suggest to all you supra owners to look into these things, as these cars run real well, but they are old and some things just don't last for ever, so you have to expect things to go now and then. Again, thank you everyone, especially Joel who sent close-up pics, I will pass them on to mechanic.
James in NJ |
#12 |
its sad that something so small can cause such trouble
88 N/A w/ 5spd - stock - not running, bhg 87 turbo/targa w/ 5spd- fidanza light weight flywheel, new oem slave cylinder, apexi air filter, no ac and no heat |
#13 |
all i can add is that you need to go into it from the side in between the IC and the radiator cavity..the latch is at the top..
#14 | |
![]() Quote:
Also...I was thinking that I will go look at my cables to have a plan if it happens to me. |
#15 | |
![]() Quote:
Thread Tools | |
Display Modes | |
Hood release cable | catawalks | Non-Generation Specific Questions | 11 | 04-24-2007 03:04 AM |
HELP!!! My Hood is stuck closed!! | opeth_07 | Exterior , Interior, and Detailing | 6 | 07-31-2006 06:02 PM |
HELP!!! My Hood is stuck closed!! | opeth_07 | MKIII Supra | 4 | 03-30-2006 12:55 PM |
what do you use to hood open your hood? | j3pz | Off Topic Forum | 4 | 01-23-2006 09:16 AM |
Got Hood Open!!!!! | scruffboy | Non-Generation Specific Questions | 2 | 12-20-2005 02:03 AM |
