Old 12-12-2005, 12:55 PM   #1
scruffboy
scruffboy's Avatar
Unhappy HELP! Can't Open Hood - Cable Snapped.
I have an 89 N/A Supra that I recently took to inspection. I failed for emissions and with some quidance and doing some reading, I found the O2 Sensor was practicaly falling off. I bougt a new one (Bosch) and installed it. Spent another 1/2 hour looking for second O2 Sensor till I realized I was looking at pics of a Calif. setup, lol. So the other day I go outside to get under the hood and check some of the other things I saw in the emmissions manual (dash pot, etc.) but when I pulled the hood lever nothing happened. The wire was there so I pulled on it but no tension. This is a brand new hood latch as the car had some front end damage which I have had fixed. I bought the parts and had them installed by a bodyshop guy I know. I am assuming he used the old cable to connect to the new latch and now it's broke. I got under car and was able to push up on lift handle with a stick, but that does not undo the locking mechanism when the hood is in the all the way down position. Any suggestions on how to get in. I was thinking of removing the little plastic radiator grill (there are 2 of them on the 89's, between the turn-signals and center-piece. Anyone out there ever have this problem? Or am I really the only person on the planet something like this could happen to?
Sincerely,
James in NJ
Old 12-12-2005, 06:09 PM   #2
j3pz
you are the only perosn in the universe that this could happen to, sorry
Old 12-13-2005, 02:34 AM   #3
SKILMATIC
SKILMATIC is on a distinguished road
Sincerely,
James in NJ
Wow, this is a dilemna. Its sounds easy but its really not. The only thing I can think of is you are going to have to take off your quarter panels in the front and romove the hood. Unless you can get it to unclock you are going to have to do this.
SKILMATIC is offline   Reply With Quote
Old 12-13-2005, 02:41 AM   #4
joel w
joel w's Avatar
huh??? not to be an ass, but how would you remove the fenders and hood, If the fender and hood bolts are under the hood and he cant open it??
you should be able to reach up under the front and release the latch with a screwdriver manually...then the second latch as normal
Old 12-13-2005, 03:07 AM   #5
SKILMATIC
Oh no worries dude. Maybe I should have explained better. You see the wheel well can be removed which are held together with plastic snaps all across the well. Then once you remove those you can get to the bolts that hold the fenders and so on and so forth. It is a pain in the a$$. Ive done it before on my mk2. Btw, I wouldve had your same assessment but the thing is he tried that already and it didnt work. That is why I had to come up with the alternative. Sorry for the confusion dude.
Old 12-13-2005, 03:11 AM   #6
joel w
joel w's Avatar
ok no prob. ill look at mine in the am , but i thought i could see the lever and cable from under the front lip, but i havent actually tried to manually pop it...
Old 12-13-2005, 03:33 AM   #7
SKILMATIC
Btw, out of curiousity someone told me that the turbo kit for your mk3 is mostly transferable to my mk2. Do you know if this is true?
Old 12-13-2005, 03:56 AM   #8
joel w
joel w's Avatar
i read that post also, sorry i really am not familiar with the mk2 yet... ive heard the engines are swappable but thats all i know. id like to know more though...
edited, when i mean swappable. i mean i hear people like to put the 7mgte into the mk2 body.. not sure on whats different about them
Old 12-13-2005, 04:04 AM   #9
SKILMATIC
Ohhhh the whole motor? No I didnt want to do that. I was wandeirn if just the kit was. O well thanks for your reply though.
Old 12-13-2005, 06:21 PM   #10
joel w
joel w's Avatar
in the pik my finger tip is on the mechanism, it can be pushed twords the drivers headlight from my finger position. (the base of the red arrow is the tip of the cable and lever..)
or there is also an access hole directly under my fingertip in the metal cover plate ( the yellow circle.) that will allow a small screwdriver to access the lever.. but since its now a leverage thing the base (handle) of the screwdriver needs to forced to the passenger side.. i can move it with my finger so the spring is not that strong...just so you know not to over due it..
Hood release cable catawalks Non-Generation Specific Questions 11 04-24-2007 03:04 AM
HELP!!! My Hood is stuck closed!! opeth_07 Exterior , Interior, and Detailing 6 07-31-2006 06:02 PM
HELP!!! My Hood is stuck closed!! opeth_07 MKIII Supra 4 03-30-2006 12:55 PM
what do you use to hood open your hood? j3pz Off Topic Forum 4 01-23-2006 09:16 AM
Got Hood Open!!!!! scruffboy Non-Generation Specific Questions 2 12-20-2005 02:03 AM
