Old 12-29-2005, 11:07 AM   #11
duster117
duster117's Avatar
duster117 is on a distinguished road
Originally Posted by suprra_girl
yep, get a block test done to check for bad hg & do a compression check... at least you'll know if the motor is reasonably good
the o-ring is what seals the cps/dizzy in the head.. it will be old and plastic now so won't be doing a hell of a lot and will leak oil onto the exhaust manifold.. get an oem replacement and you'll be sweet
good luck with the car and post some pics
pleas forgive my ignorance but what do you mean "hg"?
sorry ive never heard of a block test.
what all do they check for on the test?
duster117 is offline   Reply With Quote
Old 12-29-2005, 11:12 AM   #12
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
oh heh sorry... just habit to type the abbreviation
hg = head gasket
block test is like a rocket shaped tube with a rubber bung on the end, you fill it with blue fluid that is supplied with the kit and then put it in the top of the radiator where the cap would normally be
you then hold it in there till your thermostat opens and the water circulates... if the blue turns yellow or green you have exhaust gasses in your water
Pics of my build.
Do a diagnostic first!
Old 12-29-2005, 11:49 AM   #13
duster117
duster117's Avatar
ok now i know what your talking about
the guy already has one and has tested it about 12 times sence hes owned it
and it said it was fine.
Old 12-29-2005, 12:02 PM   #14
duster117
duster117's Avatar
btw: a dashbord light came on to. it looked like this. sorry its not very good (paint)
its supost to be a outline of the car with 6 lines coming out the back
Old 12-29-2005, 12:14 PM   #15
suprra_girl
7M POWAH! ;)
you mean like the top right
fix ur taillight, you have one bulb out
Pics of my build.
Old 12-29-2005, 12:45 PM   #16
duster117
duster117's Avatar
allright well ill be getting the car sometime next week.
think you all for your info and help
Old 12-31-2005, 03:01 PM   #17
duster117
duster117's Avatar
Talking
well im just waiting on my loan to go thrue. but i should be gitting the car by thursday!
and maby some picks on friday or saturday.
