#11 | |
7M POWAH! ;)
it will be in "vacuum" at idle... usually about -20ish on a good engine
burping Quote:
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
#12 | |
![]() Quote:
i was getting thinkin that was a bad thing caus most turbocharged cars will stay at 0psi btw sorry for jacking this thred for a lil wile |
#13 |
7M POWAH! ;)
most of your turbo cars have vacuum leaks then
![]() usually -18 to -22 is normal if it shows -10 then you have vacuum leaks (more than likely straight of the intake manifold) or (happened to me) bhg... altho that's not common i don't think mine was surging hardcore like it had a major boost leak here's some good info from www.cygnusx1.net http://www.cygnusx1.net/supra/techtip/vacuum.html
#14 |
well on the gauge on the one im getting goes from -4 to +8psi
and at idal it always says -4. is this right or is there somthing rong like a leak or somthing? Last edited by duster117; 01-10-2006 at 01:25 PM. |
#15 |
yea, mine has the same boost reading and I am wondering the same thing.
Supra Project 06... 1987 Turbo. 18" Enkei RS5. K&N Filter. Magnaflow custom exhaust. "I got a pair of subs for my girlfriend...Good traid huh?! ![]() ![]() |
#16 |
here something to think about. a turbo runs off of exhaust and when the car is started, no exhaust yet but the engine needs air to run. so the engine will suck in air creating a vaccum, thus reading neg boost. once its running and pushing out exhaust making the turbo spin, the gauge will read positive pressure
88 N/A w/ 5spd - stock - not running, bhg 87 turbo/targa w/ 5spd- fidanza light weight flywheel, new oem slave cylinder, apexi air filter, no ac and no heat |
#17 |
well, what about when the car is reved up? My trubo guage does not read uno matter how long you hold the gas down. It only reads when I am going.
#18 |
pretty much any turbo car should be pulling vaccum at idle...even cruising at low rpms. ive never ridden in a turbo supra but in a grand national it would hardly get to boost...unless he hit the gas kinda hard. would get to about 0 at normal aceleration. and vaccum while cruising. My car also has that waterfall sound...im guessing thats air trapped in the heater core?
#19 |
7M POWAH! ;)
ahh there's one thing i forgot... what measurement is your vacuum gauge in?
and yes.. burp your car too ![]()
#20 |
The boost guage reads negitive 4, then 0, then a midway line, then +8. That's it. I tried to figure out how to post a pic, but having trouble.
HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
Mk3 Turbo Problems | NicolasDwolfwood | MKIII Supra | 20 | 05-13-2008 10:48 PM |
Help...Turbo Problems | Supra_87_mk3 | MKIII Supra | 3 | 11-10-2007 07:51 AM |
Dream Offer | Karma_Supra | MKIV Supra | 22 | 10-17-2007 03:04 PM |
Sequential Turbo Question | suprapoweredsoarer | MKIV Supra | 1 | 06-06-2006 12:13 AM |
