Old 01-10-2006, 11:19 AM   #11
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
it will be in "vacuum" at idle... usually about -20ish on a good engine
burping
Originally Posted by mrnickleye
Mine had it, too. Air trapped in the heater core, cause its higher than the radiator cap.
Make sure heater water valve is open. I would by-pass the vsv for this
***note... water WILL pass thru heater core when thermostat is closed, (on a cold engine)***
Not too hot engine. Heater controls in max hot, with fan on low setting.
Using ramps, or jackstands, Raise the front of car as high as possible (I went 3 feet on mine, till the exhaust pipe tip was almost touching the ground).
Remove cap and drain off (at drain plug into pan) coolant until you can see the radiator core inside cap area. Tighten drain plug. Start engine and let idle for about 20 min. until nice and warm.
You can raise the idle up to about 1000rpm to make the water flow better.
***Note...Don't rev the engine, as it will cause the coolant to shoot out like a whale spout***
The trapped air will be forced out because doing this proceedure makes the core lower than the radiator cap.
Shut off engine, pour drained coolant back into radiator, install cap (new prefered). Lower car. Fill overflow bottle 1/2 way. Test drive.
No more waterfall sound ? Good !
I had to do mine 2x to get it all out. Next day, Check and fill 1/2 way the bottle, as the removed air will be replaced by coolant, so bottle may be low.
Pics of my build.
Do a diagnostic first!
Old 01-10-2006, 11:34 AM   #12
duster117
duster117's Avatar
duster117 is on a distinguished road
think you suprra_girl
i was getting thinkin that was a bad thing
caus most turbocharged cars will stay at 0psi
btw sorry for jacking this thred for a lil wile
duster117 is offline   Reply With Quote
Old 01-10-2006, 11:56 AM   #13
suprra_girl
7M POWAH! ;)
most of your turbo cars have vacuum leaks then
usually -18 to -22 is normal
if it shows -10 then you have vacuum leaks (more than likely straight of the intake manifold) or (happened to me) bhg... altho that's not common i don't think
mine was surging hardcore like it had a major boost leak
here's some good info from www.cygnusx1.net
http://www.cygnusx1.net/supra/techtip/vacuum.html
Pics of my build.
Old 01-10-2006, 01:20 PM   #14
duster117
duster117's Avatar
well on the gauge on the one im getting goes from -4 to +8psi
and at idal it always says -4.
is this right or is there somthing rong like a leak or somthing?
Old 01-10-2006, 05:26 PM   #15
TxSpeedBoy
TxSpeedBoy's Avatar
TxSpeedBoy is on a distinguished road
yea, mine has the same boost reading and I am wondering the same thing.
Supra Project 06... 1987 Turbo.
18" Enkei RS5. K&N Filter. Magnaflow custom exhaust.
"I got a pair of subs for my girlfriend...Good traid huh?!
TxSpeedBoy is offline   Reply With Quote
Old 01-10-2006, 07:11 PM   #16
j3pz
here something to think about. a turbo runs off of exhaust and when the car is started, no exhaust yet but the engine needs air to run. so the engine will suck in air creating a vaccum, thus reading neg boost. once its running and pushing out exhaust making the turbo spin, the gauge will read positive pressure
Old 01-10-2006, 09:40 PM   #17
TxSpeedBoy
TxSpeedBoy's Avatar
well, what about when the car is reved up? My trubo guage does not read uno matter how long you hold the gas down. It only reads when I am going.
Old 01-10-2006, 10:11 PM   #18
Isphius
Isphius's Avatar
pretty much any turbo car should be pulling vaccum at idle...even cruising at low rpms. ive never ridden in a turbo supra but in a grand national it would hardly get to boost...unless he hit the gas kinda hard. would get to about 0 at normal aceleration. and vaccum while cruising. My car also has that waterfall sound...im guessing thats air trapped in the heater core?
Old 01-11-2006, 12:30 AM   #19
suprra_girl
7M POWAH! ;)
ahh there's one thing i forgot... what measurement is your vacuum gauge in?
and yes.. burp your car too
Pics of my build.
Old 01-12-2006, 03:27 AM   #20
TxSpeedBoy
TxSpeedBoy's Avatar
The boost guage reads negitive 4, then 0, then a midway line, then +8. That's it. I tried to figure out how to post a pic, but having trouble.
Mk3 Turbo Problems NicolasDwolfwood MKIII Supra 20 05-13-2008 10:48 PM
Help...Turbo Problems Supra_87_mk3 MKIII Supra 3 11-10-2007 07:51 AM
