I am concidering changing out my bhg. But I was just wondering on the degree of dificulty for this task? What size head gasket should I get? Any one care to post a step-by-step guide to changing the head gasket on turbo charged MKlll? Besides...it's just bults and screws....right?
Supra Project 06... 1987 Turbo. 18" Enkei RS5. K&N Filter. Magnaflow custom exhaust. "I got a pair of subs for my girlfriend...Good traid huh?! ![]() ![]() |
download the free repair manual, it also has a step by step how to i think?
IM too lazy, but here is a write up that dylan wiggins did, its pretty funny too. http://photos.dylanwiggins.com/thumbnails.php?album=84 as for what headgasket to use, depends on what boost and mods you may have in mind? yup nuts and bolts , ![]() |
Riiiigggghhhhht.... well, that doesn't look too hard!
![]() ![]() Thanks alot Joel Williams, couldn't have asked for anything better.
i replaced mine with a new toyota gasket, correct me if im wrong here people, but the thickness of the gasket depends on how much material you remove from the block and head surfaces to bring it back to stock compresssion,, and or,,, you can get a thicker gasket to lower the compression ratios for higher boost potential.
some metal head gaskets are good, but require specific surfaces for proper sealing against the head and block... also if i were you, id also call around and find a good machine shop to look at your head when you get it off to check for warpage. valve adjustment and or lapping the valves even valve guide seals ecetra.. if needed or whatever.. PS;ask if them have adjusted bucket shim valves before, if they say what? keep calling around.. http://www.supra.co.nz/87tsrm/ http://groundsky.co.nz/techinfo/TSRM/ http://groundsky.co.nz/techinfo/TSRM/03_EM.pdf Last edited by joel williams; 01-17-2006 at 07:33 AM. |
There is lots of info on this out there, but I will tell you what you may not find.
If you have a digital camera, take lots of pics with hoses labeled with tape. Label things that you may lose track of. That is how I do things, and it will actually save you time, not cost you time in the long run! Others don't do this, but some may need the extra help/guidance because they may not have had their eyes on 7M's for extended periods of time, unlike other 7M gear heads ![]()
_____|_____ /. . . \ . . . \ . .\ ( ]/ . . . . \ . . . \ . .\[ ) _________________ /OO]====(W)====[OO\ [___________________] [ [O] ///______\\\ [O]_] ____________________[||]______________[||]____________________ |
#6 |
tonys right, sharpie ink pen and a box of baggies for me too..
#7 |
Sweet, that will help out alot. Knowing a seasoned professional like me
changing fuel filter | 3.0trd | MKIII Supra | 9 | 04-22-2008 10:47 PM |
Changing LSD oil. | redmaro | MKIII Supra | 8 | 04-28-2007 11:13 PM |
Issues After Changing Spark Plugs | Getphazed | MKIII Supra | 8 | 11-03-2006 12:31 PM |
changing out ring gear | Burn N' Up | MKIII Supra | 0 | 08-30-2006 07:09 PM |
Changing stock air intake. | lifesnotfair | Non-Generation Specific Questions | 7 | 01-02-2006 08:50 AM |
