Old 01-24-2006, 11:42 PM   #6
mrnickleye
mrnickleye's Avatar
If you remove the cover under the glove box (a few nuts, 10mm socket), you can look under there and see the resistor. 2 phillips screws and the connector. Pull it out and look at it. If its got bad coils, it will be obvious. Take it to auto electric to solder it, then put it back in.
Heater problem! paulmicin MKIII Supra 6 07-19-2008 12:21 AM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
heater problem..... cold like heck... hangsupra MKIII Supra 9 01-28-2007 05:35 PM
Heater Problem octron Non-Generation Specific Questions 0 04-09-2006 07:32 PM
Mk111 Heater Problem 'help' pete2bram Non-Generation Specific Questions 2 10-05-2005 09:15 PM
