Old 01-23-2006, 03:49 PM   #1
scruffboy
scruffboy's Avatar
Default Heater Problem
I have an 89 N/A and I have the push button heater controls (I hear some of the foreign cars have knobs). Well, now only the high setting works. The Low and Medium buttons will not activate the heater at all, but if I hit the High button it comes on (and works real well). No, I don't hear gurggling, so she doesn't need to be "burped". Could this be fuses? All the other switches work, like "Defrost" or "Foot Heat". But they all only work on the high setting. Also, the digital Temp readout still works, not just reading out but adjusting the heat. I think it's gotta be electrical, but I'm not sure. Any one have some ideas on what's up?
Thanks,
James in NJ
Old 01-23-2006, 03:59 PM   #2
Fuel
Fuel is on a distinguished road
I would put my money on bad connections to your buttons. If it were a blown fuse I'm pretty sure that none of the heater buttons would work.
Fuel is offline   Reply With Quote
Old 01-23-2006, 07:06 PM   #3
j3pz
ya alot of people have this problem. it is electrical. i cant say exactly what it is but i know a couple of weeks ago i saw a thread about this and how to fix it. i believe you need to soder something behind the dash, cant recall though
Old 01-24-2006, 03:22 AM   #4
mrnickleye
mrnickleye's Avatar
Go here to get the most likely answer to the problem, which is the heater fan resistor.
http://www.supras.com/06/techcenter/...6aee2ee4e99f34
This site will be very helpful for other things, too.
And if the coils are too far gone, like mine were, you can make some out of safety wire (from motorcycle shop).
PS: I haven't read a thread yet that it turned out to be a problem with connections or the buttons. Please follow up with a post as to what fixes it.
Old 01-24-2006, 12:43 PM   #5
scruffboy
scruffboy's Avatar
Default Re: Heater Problem
I could not find a post anywhere about this problem either, but the info you gave me was very thorough Mr.Nickleye. I just happen to suck at anything electrical and I have fat stubby fingers. I really can't picture me holding two small pieces of wire together with one hand, a sodering gun with the other and the soder in the other? I don't think so. We got a guy in town called "AutoElectric", I've had him do work before and he's pretty good. At least I can hand him the steps needed to do the work. Thanks for the research.
Sincerely,
Scruffboy
Old 01-24-2006, 11:42 PM   #6
mrnickleye
mrnickleye's Avatar
If you remove the cover under the glove box (a few nuts, 10mm socket), you can look under there and see the resistor. 2 phillips screws and the connector. Pull it out and look at it. If its got bad coils, it will be obvious. Take it to auto electric to solder it, then put it back in.
Heater problem! paulmicin MKIII Supra 6 07-19-2008 12:21 AM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
heater problem..... cold like heck... hangsupra MKIII Supra 9 01-28-2007 05:35 PM
Heater Problem octron Non-Generation Specific Questions 0 04-09-2006 07:32 PM
Mk111 Heater Problem 'help' pete2bram Non-Generation Specific Questions 2 10-05-2005 09:15 PM
