#1 |
I'm not really following you.
'L' position is 1st gear only. '2' position starts off in 1st, then upshifts to 2nd, and holds. 'D' starts in 1st, goes to 2nd, then to 3rd, and holds 3rd with O D button off. 'D' with O D botton on will allow it into overdrive after 40mph. The OD is actually another gear, not locking 3rd to anything. The 'lockup' torque converter locks up with light throttle position in OD. If you are cruising along in OD, if you step on the gas, like to speed up to 65mph, the torque converter unlocks, and the RPMs go up about 400 more. In other words, the lockup = about 400 rpm. The cable on the throttle has adjustment proceedures in the TSRM. It is a pressure adjustment, and tells the trans to up/down shift depending on the throttle opening.
Had a Red 1989 N/A. Automatic. Sports Pkg. w/wing. TEMS, and some nice MODS. Sold to a friend 10/08/08. Last edited by mrnickleye; 02-14-2006 at 12:04 AM. |
#2 |
k. was under the impression that L was supposed to work first, then second. 4 speed auto that locks 4 & 3 for overdrive.
... so its a 4 gear auto with a lockup that drops your revs by 400 when you're cruising. thnx. now i wont add any more posts to this thread, cos then it'll just drop off the edge of the world into the wastebasket like all dumb questions are supposed to
So I bought this old Honda bike, an NSR250. Bit of a street racer, I guess. I'm told they're fast. Delivering it home with a friend driving the Supra for the first time. I drop gears and make a scream from the twin pipes flowing down this pony's flanks and it takes off like it's tail's on fire. I look back when the Honda gets to its tap-out and the Supra's only two lengths behind. No one I've let ride my bike has told me its slow, they've all loved the thing. That car is a good thing indeed. Last edited by lethalwithasupra; 02-14-2006 at 05:30 AM. |
86.5 auto transmission removal HELP!!! | elmer | MKIII Supra | 13 | 04-06-2010 10:41 PM |
speed sensor problem | nadircicek | Non-Generation Specific Questions | 8 | 10-09-2009 05:58 PM |
Should I try to rebuild my transmission, or leave it to experts? | Busted Knuckles | Non-Generation Specific Questions | 1 | 04-15-2008 01:20 AM |
Transmission problem NEED HELP!! | supradude88 | MKIII Supra | 2 | 03-14-2007 12:54 AM |
transmission problem URGENT HELP!!! | landspeedxxx | MKIII Supra | 6 | 04-17-2006 06:13 PM |
