NEED SOME HELP PLEASE>>>>
I HAD 2 SUPRAS .1 IS THE 1984 SUPRA WITH 1 JZ ENGINE AND THE OTHER IS 1987 WITH 7M GTE ENGIN.
MY PROBLEM IS WITH THE SECOND ONE (7M) . I INSTALLED THE ENGINE AND ITS WORKS VERY GOOD, WHENE I GO OUT SUDDENLY I FOUND TOW CYLANDERS ARE NOT WORKING WICH IS 3 AND 4 ? I CHECK THE WAIERS AND THE PLUGS .I FOUND THEME OK. AND I CHEACK THE PETROL ITS OK TOO ... WHATS MAKE THAT HAPPENED ????????:dunno: :( AND WHAT SHOULD I DO ?????:dunno: :( |
Hrm...
The cylinders are just "not working" ? If you checked wires and plugs, next step is to check the injectors, I believe.
