-   Non-Generation Specific Questions (http://www.toyota-supra.info/forums/non-generation-specific-questions/)
-   -   1987 supra heater/defroster controlls (http://www.toyota-supra.info/forums/non-generation-specific-questions/429-1987-supra-heater-defroster-controlls.html)
Roxanne 02-25-2005 05:37 AM
I know this is stupid but I have had my car for 4? years and still cant figure out where to turn the heater and defroster on? Anyone know? Its a 1987 supra. Its a good thing I live in the desert and havent been suffering in the winter. Also, I have what looks like a radiator light on the left side of the dash that is on continuously. I have had many heat related problems but am not sure which problem is causing the light, anyone know.?
Thankyou for your help.
Roxanne
300hpvision 02-26-2005 06:33 PM
did u get an instruction manual when u got taht car? lol. and taht answer goes to the second one too. lol
suprra_girl 02-27-2005 07:47 AM
hmmm unfortunately i can't help you with the heater controls as jdm (aussie & nz and others) are different to us spec supras
i'm sure someone on here will help you out with that :)
with the radiator light i would say that your coolant level is low, check your water level and top it up and your light should go out :)
let us know how you get on ;)
Roxanne 02-28-2005 01:33 AM
Thankyou for your responses. No I didnt get a manual with the car.
The radiator is topped off and the light runs steadily, I, also not too long ago, changed the anti-freeze. The last time the light flickered intermittently the thermostat was bad. So I am not sure what this is about. About the time I started getting the light again I did have problems with the overflow. The water was not going back into the radiator from the reservoir after it cooled down. So I cyphoned out the water in the reservoir and started over. Since then I do not see that it is going into the reservoir but then again I forget to check when its hot, so it might be working now. But the light remains.
Roxanne
300hpvision 03-01-2005 04:54 AM
umm... maybe its BROKEN!? WHERE DID U BUY THE CAR!? DID U NOT ASK THESE KINDS OF THINGS!? kinda weird to figure it out 4 years later... <_<
