Old 05-15-2006, 02:06 AM   #1
88redsuprabp
88redsuprabp is on a distinguished road
Default horsepower
i have an 88 non turbo whats the easiest and most cost efficient way to get horsepower
88redsuprabp is offline   Reply With Quote
Old 05-15-2006, 09:13 PM   #2
Supra2NR
Supra2NR's Avatar
make urself a cold air intake jus go to home depot they got a mandrel bend machine there they could customize any angle pipes for u, then jus buy yourself a cone air filter , there u go have fun
Old 05-15-2006, 11:45 PM   #3
mrnickleye
mrnickleye's Avatar
Thumbs up Things I've researched and done
Go to FAQs section and read the "exhaust system researched' thread.
Then, a 'cone' air filter kit from an ebay store for your model. I paid $25 shipped 3 years ago. (You need the 3" adaptor in the kit to mount a filter to the AFM).
Go to the SOGI site and look up mods to the AFM. It lightens the spring tension on the trap door. Quicker throttle responce.
Get a 5/16" hose barb splice (I used a threaded brass piipe), or any piece of tubing that will fit tight, and by-pass the coolant hoses to the throttlebody. This allows the air entering the manifold to be cooler.
Cooler air = HPs.
Make sure all vacuum lines are good. Make sure Dist. cap and rotor and wires are good.
Set timing to 15*.
Old 05-21-2006, 04:04 AM   #4
327JapVette
327JapVette is on a distinguished road
Cheapest and easiest would be to add cone air filter replace cat with str8 pipe and replace muffler with a cherry bomb thats about $40.00 roughly and you can "feel the difference"
cap, roter button,coil and MSD 8.5mm wires about $65-75
Denso Iridium or Bosch Plat4 plugs, Bosch Oxygen Sensor $35-$75
Lucas off-road only fuel additive $7.00 a fill up
327JapVette is offline   Reply With Quote
Old 05-21-2006, 08:46 PM   #5
Isphius
Isphius's Avatar
I used a piece of rubber hose and the MAF is right on the throttle body, and I have a stock kind of k&n filter, and a modified airbox. I had to take the gas tank canister thing out to put it there. It makes a noticeable difference in sound and power.
horsepower supra90 MKIII Supra 3 01-13-2008 09:27 PM
does a wastegate increase horsepower supraman121 MKIII Supra 3 08-27-2007 02:49 AM
NA Horsepower Nuts supraman121 MKIII Supra 0 12-13-2006 07:57 PM
What can i do to add serious horsepower to my stock 87 supra auto-n/a? Dude wheres my supra MKIII Supra 4 11-12-2006 03:30 PM
supra/ I need horsepower Tanner O Non-Generation Specific Questions 2 09-23-2005 04:34 PM
