Air Flow Meter?
I just bought an 87 Supra and I believe the air flow meter is bad. If that is what its called, does anyone know of a way to test and be sure? Are there any aftermarket parts to bypass, or ease the cost of this part?
from all i heard,
it wont run without it, so if your car is still running you might wanna to look at sum other aspects of your car to solve what ever problem your having and by the way, no af parts for it , you cant bypass it either, all you can is move it (thats what i did) and gave me a cleaner look, and you cant paint it thats as close i got |
It wont run without it
I am quickly noticing that... I have done plugs, cap, rotor, timing, air fuel mix, adjustment on AFM itself, all I can think is the part itself is bad or whatever controlls it is bad, going to try pulling codes tomorrow, also going to buy a junkyard AFM just to see... any other ideas? Anything will help thanx,
Bert |
