Old 06-15-2006, 09:30 PM   #1
Poptart
Poptart's Avatar
Poptart is on a distinguished road
Default Hey, question on 87 Supra
Just wondering
When the cams are lined to the match marks is the rotor to be pointing on the number 1 plug wire? (In the firing order) Crank is Top dead center and cams are at match marks
Is it supposed to be pointing at number 1? Or Do you just line it up
Get back to me please
Thanks,
Ken
Poptart is offline   Reply With Quote
Old 06-16-2006, 03:58 AM   #2
Poptart
Poptart's Avatar
Hey, anybody respond please?
Old 06-16-2006, 12:52 PM   #3
IHateHacks
IHateHacks's Avatar
If the cam matchmarks are lined up with the marks on the inner timing belt case, then the cams are at TDC position and (non turbo) the distributor rotor should be pointed to the number one spark plug terminal. If it is not, then someone installed it incorrectly.
Are you doing a timing belt? Because if it is off and you are lining up the cams you still have to find true TDC of the number one piston, which you should have done long before you took the timing belt off.
So it sounds like you got it.
SUPRA LSDs AND COLD AIR INTAKEs QUESTION C0o0n Non-Generation Specific Questions 2 08-10-2008 02:33 AM
Question about the n/a toyota supra. nairb MKIV Supra 3 07-11-2008 02:27 AM
Toyota Supra Engine Question l_o_t_s_r MKIV Supra 33 08-30-2007 02:29 AM
Question to all supra owners doodad Non-Generation Specific Questions 10 08-12-2007 09:55 PM
