Old 06-21-2006, 01:04 PM   #1
Ahmad88
Ahmad88 is on a distinguished road
Default Noob question, how do i change the filter?
How do i change my intake filter, i got the 2 clips un latched but theres a part thats screwed to the engine bay, do i have to un screw that and take out the front part of the intake that goes down? can you explain step by step please, thankyou
Rollin in a 98, flippin 94's
Ahmad88 is offline   Reply With Quote
Old 06-21-2006, 03:53 PM   #2
theWeezL
theWeezL's Avatar
yes, that is the Mass Air Flow meter otherwise knnown as the MAF. you need to unscrew that from the body. Normally then you can just push everything back far enough to get the filter out. However, on old rubber hoses, sometimes you cause them to split when you do this.
I would recommend undoing the clamp that holds the hose onto the throttle body, pull that back off the TB. Now you have room to get your filter out. I highly recommend getting a cone filter and MAF adapter. They breath better, look better, and are washable/reusable. You dont need to spend a fortune on one either (K&N), as I have been very happy with the one I got from Autozone for around $12.
____________
Old 06-21-2006, 04:22 PM   #3
Ahmad88
ok thanks man preciate it i'll try that out when i get filter, you know the name of it?
Old 06-21-2006, 04:30 PM   #4
theWeezL
theWeezL's Avatar
any generic cone filter with a 3in inlet (or is that outlet?) will work. I got the cone type that has the conical inlet top so I could duct air right to it. I think I paid 12.99 at autozone. Your also going to need the MAF adapter. Autozone sells that normal stock as well. It says on the side of the box it works with our Supras
____________
Old 06-21-2006, 05:23 PM   #5
Ahmad88
preciate your help man
Product Review: AEM Dry Flow Filter 3" by 5" mkiiisupra Shops & Part Reviews 4 01-15-2010 02:15 AM
Adventures in oil change land. SephyraTigre MKIII Supra 9 06-15-2008 10:02 PM
Easy Way to Change Air Filter Benesesso MKIII Supra 7 03-04-2008 04:00 PM
K&N Air Filter D_Train MKIII Supra 6 01-04-2008 07:27 PM
Another Noob Question Jrew MKIII Supra 3 10-22-2007 03:08 AM
