Old 07-28-2006, 05:37 AM   #1
MA70_858
MA70_858 is on a distinguished road
Cool Crank shaft pulley..
Hi, I'm trying to replace the head gasket myself but I got stuck trying to take the bolt on the crank shaft pulley off. I know I have to lock the flywheel in order to do this so I took off the starter motor to access it. Then I had a friend jam the gears of the flywheel with a simple screw driver while I tried to break the bolt of the crank shaft pulley loose. However, this does not seem to be working. Any ideas on how to go about doing this? Any advice would be greatly appreciated.
Thanks!
MA70_858 is offline   Reply With Quote
Old 07-28-2006, 07:15 AM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Manual or Auto box ? I presume you are intending to change the cam belt at the same time as doing the head. To remove the head you don't need to remove the crank pulley.
Bill UK
Old 07-28-2006, 07:28 AM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Just found this link,
http://www.toyota-supra.info/forums/showthread.php?t=4504&highlight=pully
Old 07-28-2006, 04:47 PM   #4
MA70_858
My supra is a manual transmission. But thanks for that link! All that info really helped alot!
1980 Supra Crank Pulley (Harmonic Balancer) steve6163 Non-Generation Specific Questions 7 06-18-2010 01:47 AM
Crank Pulley Removal go.stfu MKIII Supra 4 07-12-2007 11:16 PM
question on removing crank shaft kidsusukigsxr Non-Generation Specific Questions 12 07-07-2007 03:49 PM
crank shaft pulley puller supramacist MKIII Supra 30 04-18-2007 02:27 AM
Unorthodox Supra Ultra S - Lightened Crank Pulleys Kuban MKIII Supra 1 03-13-2007 09:39 PM
