Old 07-26-2006, 04:26 PM   #1
malli
malli is on a distinguished road
Angry Engine problem
I have here Supra year 1995-Engine 2jz-gte
Well I have a question about a engine problem-I did just put in a new cylinder block and it has only been driven 3000 km and now it's fucked up again.
The problem is that the pistons melt and the sparkplugs do also.
The turbos are set to too 1,2 bars and the fuel pressure is normal and its run on 95 okt.gas,Timing is also ok.
Too me it look's like overboost but what do you boy?s and girls think about this and is there somebody that has had the same problem????
Thanks Malli
malli is offline   Reply With Quote
Old 07-26-2006, 10:28 PM   #2
SupraSaver87
SupraSaver87's Avatar
SupraSaver87 is on a distinguished road
Red face Your Detonating
Your problem REALLY sounds like you are detonating. Your either running too lean, or you are pushing WAY too much boost. There could be another problem that is happening, but that would more than likely encompass something with your cooling system. I would check to see if you are getting proper cooling.
I would almost put money on detonation though. Gotta watch those aluminum heads. I am sorry to hear about your problem though, sounds like its a costly fix.
My Ride: http://www.cardomain.com/ride/2351563
Our Supra’s, which art in the driveway,
Hollowed be thy power, thy mods are great, thy speed endless,
On the road or at the track. Give us this day free of cops,
And forgive us our impound charges, as we forgive those who are slow.
And lead us not into speed traps, and deliver us from the interceptors,
For thine is our car, the power, and the glory…forever and ever….amen.
SupraSaver87 is offline   Reply With Quote
Old 07-26-2006, 11:35 PM   #3
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
absolutely detonation
get your fuel pressure checked when wot
make sure you injectors are not clogged
and have you ever been on a dyno? never should you turn boost up without some sort of monitoring device for your fuel system
best bang for the buck = zeitronix zt2 air fuel wideband meter www.zeitronix.com
Pics of my build.
Do a diagnostic first!
Old 08-01-2006, 12:44 AM   #4
Toyotafanatic
Toyotafanatic's Avatar
Toyotafanatic is on a distinguished road
Yea detonation, really freakin lean or overboosting like hell, not sure how to get it tested listen to the other guys with MKIV's.
BOOST IT!
Toyotafanatic is offline   Reply With Quote
Engine Problem 86toySupra MKIII Supra 3 04-17-2007 04:50 PM
engine problem nickalvrz Non-Generation Specific Questions 5 10-16-2006 02:51 AM
engine problem... sboy MKIII Supra 6 02-03-2006 01:09 AM
Jdm engine rev problem Wicked19 MKIII Supra 3 11-08-2005 02:42 PM
