#1 |
Hello i have a 87 n/a automatic. I want to swap to a turbo 5 spd. I found this list on supracharged.com (http://www.supracharged.com/4runner/...partslist.html) and i was wondering if this was a good part list to look off and for the ecu does it have to be same year/engine/transmission to be able to have the engine work properly with the trans. If you think that there should be a couple parts added to the list or if i dont need a couple of the parts please let me know.(this guide is for swaping the engine only)Thanks
#2 |
can you put some parts on a 7mgte motor from a 7mge?
#3 |
why tho?, but maybe sum of the internals are the same and can be used for both engines , ask around sum more
http://www.myspace.com/supra_2nr ![]() Into Bikes now,, apparently the supra couldnt kill me, so my zx6 might lol |
#4 |
why what? why change over parts? Because i need to save money.
#5 |
i knew it
say where do you stay at in chicago im also looking for parts and maybe you and i can help each other out in here
#6 |
difference in engines: cams, pistons(compression), gte has oil squirters, obviously turbo, ic, and exhaust manifold, the ge has a y from tb to intake manifold, and # of knock sensors, ge has one gte has two... just learned that yesterday
to go from ge to gte you need most of the above
88 N/A w/ 5spd - stock - not running, bhg 87 turbo/targa w/ 5spd- fidanza light weight flywheel, new oem slave cylinder, apexi air filter, no ac and no heat |
#7 |
i live in the south suberbs and ya ill let you know if i find anything cause im going over the place for these parts. if you want just let me know what kind of parts an dill keep an eye out.
#8 |
im looking to buy a complete 7mgte engine with everything, intercooler, ecu and other goodies that it comes with, and if available and price is reasonable
i might buy the turbo tranny
#9 |
ya if i find any extra parts ill let you know.its just hard finding one set of parts but ill deffently keep an eye out
#10 |
appreciate it
maybe after this is all said and done we can race
Thread Tools | |
Display Modes | |
performance parts swap | HINsupra88 | Non-Generation Specific Questions | 0 | 03-18-2005 07:38 AM |
