Old 08-10-2006, 12:32 AM   #1
supra67
supra67 is on a distinguished road
Default Dash lights Don't Work
Quick ? I have an 89 supra turbo the dash lights, fog lights, and driver side head light do not work. Everything else works fine such as passenger headlight, (High beams work on both headlights), taillights, turnsignals, hazard, rpm, speedometer, boost, oil pressure. I just bought the car for $900 bucks it was a good deal. I figured that maybe it was a burnt fuse, but I checked all the fuses and they are all fine. Does anyone have an idea what the problem might be?
supra67 is offline   Reply With Quote
Old 08-11-2006, 11:51 AM   #2
suprasforlife
suprasforlife is on a distinguished road
Tried replacing the head light? Have you checked the wires to the fog lights? Is the dimmer turned all the way down for the dash lights?
I have an 89t also and when I got it my dash lights did not work either, replaced the fog lights that where wired in it like complete shit and the dash lights worked again. Not sure if it was just lucky or if they are connected in some way, I just know the fog lights where put in by a retard, they used duct tape to cover the splices and one light was green and one was purple, I put a matching set in the right way and everything works now.
Somebody else know if they are connected some how?
suprasforlife is offline   Reply With Quote
Old 08-21-2006, 01:13 AM   #3
supra67
Yeah, I replaced the headlight already but no luck. I fixed the dash light the idiot that sold me the car had the white face guages installed but had the wires hooked up wrong. Still no luck with the driver head light
Old 09-03-2006, 10:25 PM   #4
Isphius
Isphius's Avatar
Kind of old thread, But my dash or climate control lights also dont work, No burnt fuse. Is there a relay or something related? when i put the headlights on, The CC panel lights up and then goes right off, Like very very fast. Its just a flash. I dont know whats wrong with it. any help?
Old 09-05-2006, 04:58 AM   #5
Isphius
Isphius's Avatar
Ok i fixed it...bad dimmer switch. I just jumped it on all the way.
supra dash lights wilkoo2 MKIII Supra 1 11-04-2008 04:02 AM
Dash lights and Side marker lights are not working ebang MKIII Supra 0 04-01-2008 12:35 PM
Dash lights Furious1 MKIII Supra 5 03-30-2007 05:50 PM
Dash lights Don't Work!! supra67 MKIII Supra 0 08-10-2006 01:11 AM
Dash lights not working! Rommy MKIII Supra 6 05-17-2006 03:55 AM
