any adjustable shocks for '85 supras? any suggestions?
restoring with a touch of performance. future mountain carver. genesis - 1:23 " and god said unto the canyon folk, turn fast, stop fast, then go fast. And the canyon folk agreed and it was all good." |
fOR mkII's i suggest sticking with non-adjustable shocks. unless you have TEMS.
1988 Toyota Supra Turbo Targa Tokico Illumina II's (TEMS) | Eibach Pro Springs | SpeedTech AntiSway Bars | Cusco Strut Tower Bars | Lexus AFM/550cc Injector Mod | SOGI short shift mod | Aluminum Driveshaft | Upgraded Fuel Pump | 12 PSI Boost | MHG | 11/30/08 Dyno 362RWHP 326ft/lb ![]() |
what if i did go with adjustables rather than non-adjustables?
There shouldn't be anything wrong with putting adjustable shocks on ANY car if you can find them. Before you start looking make sure you know why you want them. Is it for road course type handling...street drags...or just to lower it for looks?
Once you decide that for sure that will narrow the search and maybe prevent you from wasting money if you only want looks. After that (sorry I can't be more help) start searching the web and talking to your local shops. I have an '88 and it's getting hard to find good after-market stuff for our older cars. I put TEIN Flex on my car but I don't know if TEIN makes anything for '85's. Plus I go to the track once in a while so I reluctantly spent over $2,000.00 for coilovers with the optional inboard electric damper adjustment. (about $1,800 without the luxury of the inboard damper deal) If you just want to lower for looks, maybe $300.00 for your car??? Just think about what your doing and you will be fine. |
Lowering for looks all you need is lowering springs to do it right. Or you can ghetto it and just cut a couple coils off it. Either way get an alignment afterwards or you'll spend more on tires/bushings from excessive wear than you did for the alignment.
1989 N/A Targa 5spd. Metallic Grey, w/grey interior. No mods done. |
#6 |
for now, i plan on doing suspension set up for the road. i still don't know what i want from the engine, since its a bit on the weaker side of things. no drifting or drag for me right now. (not much money as of now) its almost a daily driver. i'm not really interested in modding the body or anything. the look itself is pretty sick, in my eyes. i'm just stickin with suspension work then engine. basically working to make a fast roadster?
restoring with a touch of performance. future mountain carver. genesis - 1:23 " and god said unto the canyon folk, turn fast, stop fast, then go fast. And the canyon folk agreed and it was all good." Last edited by edelmar417; 10-30-2006 at 10:27 PM. Reason: none |
What Shocks Should I Look Into? | Chambers | MKIII Supra | 10 | 07-08-2008 11:52 PM |
TEMS Replacement Drop-In Shocks | mrnickleye | MKIII Supra | 2 | 08-13-2007 01:16 AM |
adjustable shocks | edelmar417 | MKII Supra | 4 | 02-27-2007 09:14 PM |
