Old 10-26-2006, 11:27 PM   #2
mrnickleye
mrnickleye's Avatar
Default easy job
If the bolt broke when tightening it, and NOT when removing it....then you can use a small drill bit and an 'easy out' to remove the piece.
They aren't cheap, but I've had good success using 'left hand' drill bits, because the piece will often unscrew as you start to drill.
A Little Story about a crank bolt abhattan MKIII Supra 17 03-28-2013 01:06 AM
Broken Thermo Bolt scruffboy MKIII Supra 17 10-08-2010 01:03 AM
Targa Top bolt is striped out gtmustangman MKIII Supra 7 02-08-2009 02:41 PM
stripped rear end bolt 87 Supra MKIII Supra 5 10-16-2007 02:40 PM
how do you get to the top bolt on the starter? TATTOOED87TURBO Non-Generation Specific Questions 3 02-21-2007 06:52 PM
