-   Non-Generation Specific Questions (http://www.toyota-supra.info/forums/non-generation-specific-questions/)
-   -   engine swap (http://www.toyota-supra.info/forums/non-generation-specific-questions/6795-engine-swap.html)
dom747 11-15-2006 05:47 AM
engine swap
hey i was wondering if i would be able to swap my 7mge engine out of my 86 supra and put in a jdm 2jz-gte engine? is that possible?
dcrusupra 11-15-2006 06:06 AM
Not without a lot of work. But yes, there are hundreds of them running around out there.
dom747 11-15-2006 06:07 AM
what kinda of work am i looking at???
burton51m 11-16-2006 03:49 AM
this isnt sumthing you just plop right in...you have to do a lot of fabricating.
you need..
1 2jzgte obviously
2 harness both the 7m and the 2jzgte
3 u need a 89+ round mount cross members some 89s do have square mounts to beware of it
4 turbo headers or manifold for a single turbo (unless u plan of fu<king up the fire wall)
5 turbo ur choice
6 motor mounts the 2jz
7 ecu-either stand alone or 2jzgte
8 fuel pump either the tt fuel pump or a walbro 250lb
9 elec fans cause the 2jz does not use the sameones also helpsout on parasitic hp drop
10 hybrid clutch and fly set up (if using manual)
11 tranny (well depends either 1jz bellhousing for the r154 out auto tranny or a getrag-v160 which involves alot of work)
12 ic
13$$$$$$$$$$$$$$$$$
tone loc 11-16-2006 04:54 AM
yeah i here its a bitch not just the money but the time and work u need
dom747 11-16-2006 06:21 AM
well thanks for the input guys, would i be able to do up the 7mge with some power, i just want a car to be able to drift on dry pavement
tellfromchico,ca 11-16-2006 06:26 AM
id start with a 7mgte lsd diff if u like to drift , lucky me my stock 89 7mgte came with one. also why not keep it simple and go with 7mgte swap?
tone loc 11-16-2006 09:03 PM
yeah plus singal turbo is better
dom747 11-17-2006 12:40 AM
ya...well is it hard to swap it to a that?..
tone loc 11-17-2006 02:16 AM
no matter what its hard labor but its a lot easier because it bolts right to the tranny and no fab is needed
dom747 11-17-2006 02:58 AM
ok, thats cool then, soo with 7mge there is no way i can get some more power out of it and put a turbo on it? ..?
tellfromchico,ca 11-17-2006 06:44 AM
you'll end up needing to modify too many parts to turbo your ride its cheaper to just swap it with the 7mgte for you n/a guys turbo is definetly a completly different excitment, especially when you pass those 5.0s buy!
http://www.jdmenginescorp.com/index....products_id=22
supraman121 11-17-2006 10:24 PM
ya dude im looking to upgraded to a 7mgte cause this none turbo thing is not working lol but i was told if i switch to a turbo i should upgrade my clutch
