O.K., so I got the check engine light to go off by replacing the broken Coolant Temperature Sensor. But now my car idles at 2000 rpm's! When I disconnect the sensor, it will drop down to 1100. Not the 800 I'm used too, but better. Can I drive without this sensor? When I connect it, the car drives all jerky and stuff, but disconnected, it drives much better. Does anybody have any idea what is going on here? This is driving me insane. Someone please help me.
Thanks, Scruffboy |
AEM EMS
Did you replace the sender unit with the correct type and was it running ok with the old unit you glued together.?
Yeah Bill, I replaced it with one that looked exactly like it, same set up. The old one looked so coroded that I'm not sure it was really working, maybe just enough to keep the engine light off, I mean I saw no metal to metal contact on the broke one. Can I run without the temp sensor? Maybe I just need to have my idle adjusted, and then hook it back up. I'm just not sure. I don't know if this could mean anything, but I did not wait for the coolant to cool all the way down before I replaced it. Could putting it in without waiting long enough have destroyed it? Thanks Bill UK, I appreciate you responding.
Scruffboy |
The heat did not harm it. It sits in hot coolant. I suspect other problems.
"I" would first try disconnect the negative battery cable for a few minutes, to clear the ECU. Then I would hook it up and start the car. Normally you need to drive the car for a few city miles, and start and stop the engine a few times, let it idle a few minutes, etc. Doing all this, the ECU re-learns. Normally after this, the idle settles down to 700-850rpm.
I had already done everything you mentioned. I disconectted the negative battery cable for a few minutes figuring that would clear the memory. I drove around in stop and go traffic several times. I raced the engine a little bit hoping that that would "settle it down", but no go. In the morning I have to hook it up to get it to turn over. Then I pull it out just enough so that there is no connection. The Check Engine light comes on, but the idle drops to 1,000. Could the fact that we are having a cold snap here have any bearing on this? It's been dipping into the upper 20's to low 30's overnight. Anyway, I have this really good "Ultra Copper" gasket maker and I used it to put the old one back together. This weekend I will swap it out and see what happens. If I can't resolve this issue, can I go to my own mechanic, or do I have to go to a Toyota dealer? I'm not used to cars with computers and diagnostic codes and such. Would my mechanic, who I trust and is very reasonable, (I found him by word of mouth) be able to hook this car up and find out what's wrong?
Thanks, Scruffboy |
#6 |
AEM EMS
It does sound like your new sender unit may have the wrong resistance values, did you obtain this from Toyota ?
Want to buy a Supra, though having some problems finding one. | Cypherbku | MKIV Supra | 3 | 03-03-2009 01:45 AM |
problems problems problems.... | 86SupraMan | MKIII Supra | 5 | 02-04-2008 04:28 PM |
Starting problems and accleration problems! | alekjame22 | MKIII Supra | 6 | 03-17-2007 11:19 PM |
Oil leak problems | adellicson | MKIII Supra | 1 | 03-04-2007 10:11 PM |
problems, problems, and problems | tone loc | MKIII Supra | 6 | 09-06-2006 04:35 AM |
