Old 12-12-2006, 12:41 AM   #1
quamme
quamme is on a distinguished road
Default lower timing gear
i have a 85 supra that on the lower timing gear keeps losing a chunk from the top of the woodruff keyway. and then either ruining the seal or just allowing oil thru. it does not appear that the seal was damaged the second go round of replacing the gear. any ideas on what it could be. thanks.
quamme is offline   Reply With Quote
Water in Oil???? HG??? Z'mnypit MKIII Supra 27 05-03-2007 12:40 AM
Noise Inside Lower Timing Cover mrnickleye MKIII Supra 10 04-26-2007 05:14 AM
Timing belt rubbing against lower front cover adamh88 MKIII Supra 4 01-05-2006 11:08 PM
