-   Non-Generation Specific Questions (http://www.toyota-supra.info/forums/non-generation-specific-questions/)
-   -   turbo (http://www.toyota-supra.info/forums/non-generation-specific-questions/7054-turbo.html)
dom747 12-12-2006 04:17 AM
turbo
hey...i no i have asked this already, but iwas wondering., would i be able to put a turbo on a 7mge if i dropped the compression on it but getting a different head, i have been told that, by doing that i can put a turbo on that engine with out doing a engine swap, is that true?
Bill UK 12-12-2006 06:13 PM
The 7M-GTE has extra lubrication jets/nozzles for the cooling of the big-end bearings and oil feed and return connections to & from the turbo to the block. The pistons are different and the cranks also differ between model years. They both may have the same cast block initially but are fitted with different components. Late model cams have a chamfered oil journal inlet to aid the oil feed.
