Old 01-04-2007, 05:27 PM   #1
scruffboy
scruffboy's Avatar
Default "mechanical" throttle adjustment?
I am having trouble adjusting my throttle down the last 200 to 300 rpms. It idles at 1000, but I do not believe it is an electronic problem. When the gas pedal is depressed, the linkage separates a part from the dash-pot sub-assembly. When released, they come back together. If at that point I manually push it in a little further I can get the idle down to 800. As soon as I pull on the linkage and seperate them, when they come back together it idles at 1000. I see there are springs that control the linkage rods. Is it possible mine are worn? Should I attempt to turn the idle screw (actually a nut) to get the idle down? Any suggestions folks?
Scruffboy
no throttle in gear weol66 Non-Generation Specific Questions 0 07-26-2008 01:04 PM
lost of power at full throttle?? peedamonkee MKII Supra 4 01-08-2008 05:50 AM
Jdm Throttle Body Luvs2slide MKIII Supra 1 07-24-2006 07:15 AM
Throttle response f00g00 MKIII Supra 1 04-13-2006 12:57 AM
throttle body 87supraguy MKIII Supra 0 02-17-2006 02:40 AM
