Old 01-08-2007, 02:02 PM   #1
unkymurch
unkymurch is on a distinguished road
Default 1991 Supra - Broken Front License Plate Screw
Recently purchased 1991 Supra. When I went to put on my new plates, I discovered that the driver's side front license plate mounting screw was broken off right at the surface, so I can't mount my required front plate. Do I have to remove the front bumper to see and fix the problem or should I try to drill it out through the small hole. Any suggestions?
Thanks
unkymurch is offline   Reply With Quote
Old 01-08-2007, 02:15 PM   #2
Supra2NR
Supra2NR's Avatar
Default don't drill
They sell little square plastic fasteners where you can screw the plate in
At local auto store
Or even the metal clamps with a hole for the screw
Try that first b4 drilling anything
Supra MKIV Front Grill Durandal MKIV Supra 2 10-01-2008 02:01 AM
