#1 |
ok so, were to begin. i have a toyota supra 1989 n/a 7mge engine, automatic. i have recently replaced the headgasket. it was running b4 headgasket was removed. now i have replaced the head gasket and it will not start. engine cranks, is getting spark, fuel. everything needed to start. has plenty fuel, and is new. have replaced cap rotor with new one, spark plugs wires, coil, bout everything...all wiring is fine...now i have replaced the cold start injector, switch. timing is dead on and the distributor is dead on. it will crank fine. it will sputter like it will start but nada. weird thing is b4 head gasket replacement it would start on first crank and run but blow white smoke. now nothing. have tried with old and new components. have messed around with timing tryin to figure out what is wrong but come up with nothing...can anyone help please..! i really would love to drive it again. thanks, bill.
