#3 |
AEM EMS
A whistling noise from a MK III Turbo normally indicates the four mounting nuts holding it on to the exhaust manifold are loose, allowing combustion gases to escape via the turbo gasket. This is quite common if the top or bottom turbo support brackets are missing. But from the year you have stated you are referring to the MK IV Supra. Re Post your question in the MIV 1993-1998 section you may have better luck with an answer.
TURBO's Anyone? | Luvs2slide | MKIII Supra | 0 | 08-16-2006 03:28 AM |
Whistling Noise | DarkRaiderz | MKIII Supra | 3 | 03-21-2006 02:14 PM |
Twin TD07-25G "T-67" Turbos on a 1JZ or 2JZ *pics* | kingtal0n | MKIV Supra | 1 | 03-20-2006 02:36 PM |
replaceing turbos (ct12's)....need help.... | sexy91tt | MKIII Supra | 0 | 02-10-2006 10:35 PM |
