Old 02-09-2007, 08:34 PM   #1
kidsusukigsxr
kidsusukigsxr is on a distinguished road
Default Igniter Plug
Hello
88 auto turbo engine. My question is do i need to have the igniter plugs connected in order for my car to start up? Or will the car run and start up with out the igniter plug in somewhere.
thanks
kidsusukigsxr is offline   Reply With Quote
Old 02-10-2007, 04:09 AM   #2
kwnate
SP58GT
your car won't start without it plugged in. No spark no fire...
Nate
Old 02-10-2007, 01:46 PM   #3
kidsusukigsxr
well heres my problem. no where on the car can i find the plugs to plug underneath coils. Is it supposed to be on the coil pack or harness? can i buy it seperate? What can I do?
Thanks
Old 02-10-2007, 02:55 PM   #4
IHateHacks
IHateHacks's Avatar
"no where on the car can i find the plugs to plug underneath coils. Is it supposed to be on the coil pack or harness? can i buy it seperate?"
Sounds like you are missing the harness for the coil packs? It is only on a GTE engine harness, and it looks like this- 3 black 2 terminal connectors on one end that plug into the coil packs and 1 green colored connector on the end that plugs into the main engine harness. The green one looks just like the one for the cam position sensor. I'm sure you can get just that part of the harness from the dealer, but that won't help you if you have a GE engine harness.
The igniter is that silver box behind the diagnostic connector behind the battery. Has a 6 terminal connector and a 4 terminal connector coming out of it if its for a GTE.
Old 02-12-2007, 08:46 AM   #5
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
^ informative reply
if you need the coil harness lmk as i have a spare
Pics of my build.
Do a diagnostic first!
Old 02-16-2007, 04:01 PM   #6
kidsusukigsxr
Hello Suprra girl
yes i'd be interested. how much do you want for it? and do you have an ecu auto 88 turbo yellow connection at the end.
Igniter help ranterbul Non-Generation Specific Questions 4 04-19-2018 05:42 PM
Transmission filler plug elsleepster Non-Generation Specific Questions 3 11-02-2008 04:44 PM
Igniter Question Jrew MKIII Supra 2 01-05-2008 02:02 PM
Plug or hose came off back of block f00g00 MKIII Supra 3 05-20-2006 11:01 PM
new mk3 owner, spark plug galley full of oil!???? katillidie MKIII Supra 6 03-24-2006 05:09 AM
