Old 02-19-2007, 09:36 PM   #1
TATTOOED87TURBO
TATTOOED87TURBO's Avatar
TATTOOED87TURBO is on a distinguished road
Default how do you get to the top bolt on the starter?
i am having trouble getting the top bolt off. i can barely get to it, the bottom bolt was a breeze. is there a way to get to it that will help me. and mabey tools that i should use ( like using small wrench or long wrench, socket) please help me start my car! thank you verry much. gary
TATTOOED87TURBO is offline   Reply With Quote
Old 02-20-2007, 03:35 AM   #2
IHateHacks
IHateHacks's Avatar
I had to take off the heater hose and the egr valve to get to my top starter bolt. And I had the upper intake manifold off also.
Even with all of this off it was still a bitch to get at.
Have fun!
Oh and if you use a short shank (about 4") 14mm closed end wrench on the bolt head (part of the bolt facing the trans) it will help.
Old 02-20-2007, 05:14 AM   #3
TATTOOED87TURBO
i going to take it in and have a performance shop do it for me. i'm going to have them check the small stuff first. and do you think the starter from my new jdm will work fine? if its the starter thats bad, because when it failed it was an on going thing, some times if i keep turning the key and click the shit out of it, it woud start. and then i had to jump start it. is it going to be safe to push start it to get me to the shop, its a 1/4 mile. thanks agian!
Old 02-21-2007, 06:52 PM   #4
j3pz
could be worn teeth on the starter or flywheel along with a number of other things.
90 mkIII starter connections doodah MKIII Supra 1 11-11-2008 06:14 PM
I HATE MY STARTER SO MUCH (1987 Supra) RNEMESiS42 MKIII Supra 12 02-23-2007 11:25 PM
Broken Bolt scruffboy Non-Generation Specific Questions 6 10-31-2006 01:33 PM
