Old 02-23-2007, 08:25 PM   #1
unkymurch
unkymurch is on a distinguished road
Default 1986.5 Non-Turbo with blown Head Gasket - Removing Spark Plugs
Advice needed for how to remove all the spark plugs.
I put my sputtering 1986.5 Supra with a blown head gasket in the garage until I figured out what to do. After just a few weeks, I tried to restart it a few days ago, but it was a NO GO.
I was told to remove the spark plugs and cycle the motor to blow out the coolant that may have filled the chambers and then it would restart.
I can see and touch three plugs but three are underneath all the mechanisms of the engine.
What is the minimum I have to remove to gain access to the hidden three spark plugs? It's very intimidating too see how much has to be removed to get all the plugs out.
Is there some free internet diagrams or procedures with pictures that would tell me how to do this? I have a Toyota Shop Manual but it is useless in explaining how to remove the spark plugs.
Any advice and words of wisdom would be appreciated.
Thanks,
Mitchell
Last edited by unkymurch; 02-24-2007 at 02:31 PM. Reason: Specify it was a Non-Turbo Supra
unkymurch is offline   Reply With Quote
Old 02-23-2007, 11:19 PM   #2
ddmcse
ddmcse's Avatar
Cool
i would drain some motor oil to see if water comes out first before the oil
oil floats ontop of water
this will give you some kind of indication of how much of a blown gasket you are dealing with
i wouldn't start it just for ha ha's
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 02-24-2007, 01:59 AM   #3
damdog05
damdog05's Avatar
damdog05 is on a distinguished road
the mininmum youd have to remove is the throttle body. go here and it will tell you how to remove it. or do what i did and just go figure out how to take it of...took me about an hour the first time. just make sure to take pictures so you can have a reference for when your putting it back together. it may seem daunting but its really not once you get into it.
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
damdog05 is offline   Reply With Quote
Old 02-24-2007, 04:39 AM   #4
IHateHacks
IHateHacks's Avatar
"Advice needed for how to remove all the spark plugs"
Is it turbo or non-turbo?
And if you are afraid of taking stuff off to get at the plugs, if you are replacing that blown head gasket, you're in for a rude awakening .
Old 02-24-2007, 05:31 AM   #5
damdog05
damdog05's Avatar
well, i went on the assumption that it is not turbo since they didnt make em in 86.5, but if its been switched you will have to remove other stuff
My cars:
Old 03-02-2007, 01:08 AM   #6
unkymurch
Any chance there are pictures or even a video clip of what to remove to be able to access the spark plugs. Taking BEFORE pictures is wise advice and I'll do that, but I'm afraid of taking or dismantling too much or maybe not enough.
Is not, perhpas I should make my own.
Mitchell
Blown Head Gasket Symptoms! Dejvid1785 MKIII FAQ 76 04-24-2011 07:59 PM
Blown Head Gasket Snake Oil unkymurch Non-Generation Specific Questions 21 08-06-2010 02:11 AM
Update: Blown Head Gasket Snake Oil - 8 months later unkymurch Non-Generation Specific Questions 3 12-17-2008 09:35 PM
Blown head gasket? h8z2luze MKIII Supra 30 06-03-2006 03:18 AM
