-   Non-Generation Specific Questions (http://www.toyota-supra.info/forums/non-generation-specific-questions/)
-   -   Overheating (not bhg) (http://www.toyota-supra.info/forums/non-generation-specific-questions/7927-overheating-not-bhg.html)
scruffboy 03-18-2007 03:04 PM
My car was blowing coolant into the overflow tank but I did not want to post about it because I knew everyone would jump to the conclusion that it was a blown head gasket. I did some detective work and found the problem. I had bought an aftermarket radiator cap with one of those e-z release levers. Well that was shot, so the coolant had no place to go but into the overflow. The coolant is still green, the oil is not milky, and now I can go on my merry way.
Scruffboy
P.S. Do not buy those radiator caps with the orange lever, they suck.
mrnickleye 03-18-2007 06:38 PM
Those 'quick release' caps where invented for use on those old cars that did not use the overflow bottles.
The radiators were like ours, in that they had a top tank. But, those cars were designed with BIG tanks (like my '65 Fury), and you leave an inch or 2 or air on top.
As the pressure builds, the air compresses (water does not), and they only over flowed when there was a problem, or, occasionally, when it was "extremely" hot outside.
You could release the pressure safely with the lever because of the air on top.
