Old 04-17-2007, 04:05 AM   #1
swied
swied's Avatar
swied is on a distinguished road
Default wont start?
man this really sux!!! As in my last post we got it moving!!! Now it wont start. Put a new battery in it and all the lights work and all that good stuff! We tapped on the starter and nothing happens. What could it be?
swied is offline   Reply With Quote
Old 04-17-2007, 04:37 AM   #2
mrnickleye
mrnickleye's Avatar
Smile
Are you saying that you have everything hooked up, but the starter does not crank the engine over????
SECURITY SYSTEM ?? Try locking and unlocking the drivers door with the key. That's what re-sets the system.
Get a starter jumper button fron a parts store or tool outlet. Hook it up to the starter and see if it cranks. Yes, then perhaps the starter relay is not getting juice, ignition switch??
Use a test light and the TSRM wiring diagram to trace it down.
http://www.cygnusx1.net/Supra/Librar...ction=D&Page=1
I wish you luck, and all green lights.
Old 04-30-2007, 03:50 PM   #3
Mick
Mick is on a distinguished road
Default Supra won't start,
Thanks. for the post. My son and I will try the above, but one thing, We had charged the battery about 2 weeks ago, started it and took it on a test drive, all was fine, Sat. we tried to start it, and no reponce. check battery, had a charge putting out about 11.48 volts, lights and so on works fine. cleaned battey connections, ground to body and ground to block. any other suggestions.
Thanks Mick.
Mick is offline   Reply With Quote
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
