Old 05-04-2007, 03:22 AM   #1
suprabahamut
Default head gasket
If I remove the head to check the gasket, if it is okay can I just put the head back on and reuse the gasket or do you have to buy a new one. and with the valve cover can you use rtv gasket maker to make the valve cover gasket, and what other gaskets can you use rtv gasket maker to make new gaskets with out the larger expense
Blown Head Gasket Snake Oil unkymurch Non-Generation Specific Questions 21 08-06-2010 02:11 AM
Head Gasket Part II Bullz_EyE MKIII Supra 2 01-26-2006 06:30 PM
