Old 05-11-2007, 06:36 AM   #1
dannydavi
dannydavi's Avatar
Question Tilt Steering wheel?
hello again all, i had a question about the tilt function on the steering wheels of these cars. i may be losing it but i am almost sure it has different settings (vertically) i went to drive in theater today and tilted it down cause it was sticking over the dash and in the way of movie, at end of movie i went to tilt it back up and there were no other settings other than the one at the bottom.. which is not what im used to, my thighs rub on the way out it's all around gay.. either way i was wondering if yall can check your tilt let me know how many dif height settings it has, and what exactly you do to get it to stay at that settings. Dumb question i know but i cant stand the really low setting. thanks in advance guys
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 05-11-2007, 02:40 PM   #2
There are 2 levers. The easy to reach one is to quickly release it to lift up so you can exit the vehicle easier.
The other, further down and under, is the position setting lever. Play with it to figure out where you want to NORMALLY leave it. Use it to lower for long drives etc.
Old 05-11-2007, 07:31 PM   #3
dannydavi
dannydavi's Avatar
thanks. I only found two levers last night, one for telescoping and the quick release, but i guess i was tired and it was dark so i'll go out on my lunch and take a look. I knew i had it higher before..
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 05-12-2007, 12:01 AM   #4
dannydavi
dannydavi's Avatar
mwahahahaha i found it.. all it took was a lil day light.. a lil guy on the bottom of column, thanks nickeleye
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Having Trouble Removing the Steering Wheel Chambers MKIII Supra 3 06-30-2008 01:03 AM
Aftermarket steering wheel RTZ MKIII Supra 10 02-07-2008 08:44 AM
Steering wheel off-centre colin172 MKIII Supra 3 10-06-2006 01:41 AM
What do i need for my steering wheel. paula Non-Generation Specific Questions 1 07-17-2006 01:03 PM
Steering wheel. lifesnotfair MKIII Supra 11 12-30-2005 12:26 AM
