Old 05-22-2007, 10:07 PM   #1
wurvan
wurvan's Avatar
wurvan is on a distinguished road
Default Power Steering Leak
My 87 Supra Non-turbo, has started to leak, actually squirting fluid from the passenger side rack & pinion boot, I have had one shop tell me that you cannot replace the boot and must replace the entire rack, I have replaced the boots on other cars and it fixed the leak just fine , but after checking another place they said something similar but wasn't sure if you had to replace the rack or not.
Anybody know for sure?
wurvan is offline   Reply With Quote
Old 05-23-2007, 01:39 AM   #2
mrnickleye
mrnickleye's Avatar
Thumbs up Do it yourself
Yes, I DO know. The 'boot' is ONLY a dust and dirt shield. The seal that is leaking is in the rack. You must replace the rack with a remanufactured one,(unless you are very rich and want a NEW one).
Carquest price (reman) is $146 net, to $246 list.
Its not hard to do. I did mine in 2hrs tops, in the driveway on ramps.
PS: If someone would make a nice (seperate) thread on how to do it yourself, I will sticky it in the FAQs section.
power steering pump daluxsrt4 MKIII Supra 1 08-29-2008 02:17 PM
Power Steering Pump and Fluid Chambers MKIII Supra 8 06-29-2008 03:59 PM
Power steering pump carfanatic89 MKIII Supra 1 09-15-2007 04:16 AM
Power steering pump.. 89 turbo. 2JZEFINI-17 MKIII Supra 4 03-13-2007 03:23 AM
Power steering fault david small Non-Generation Specific Questions 1 09-20-2006 12:41 AM
