Old 07-08-2007, 07:43 PM   #1
v8shadow
v8shadow is on a distinguished road
Default brake juder
hi there i'm new to the site i've got a 1989 3.0L N/A in red
i got the car as i've had to go to a auto due to a disability and i thort i'd treat myself.
i've got a brake juder i've replaced the front disc and pads cheaked the ABS system and wheels yet it still dose it any help on this one would be appreciated
v8shadow is offline   Reply With Quote
Old 07-09-2007, 01:31 PM   #2
SupraDupra
SupraDupra's Avatar
Perhaps worn wheel bearings? Can you wiggle the wheels with the front jacked up? Has the problem changed in any way with the new parts on? Did you replace the pads and disks on both wheels? If everything else is legit you may have to question the calipers next.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 07-09-2007, 06:00 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
I had the same problem some years ago; the steering wheel and brake pedal would judder when braking. I assumed it was the front disc's running out of true, so I replaced the disc's and pads on the front but it made no difference. It wasn’t until I replaced the rear disc's (which were very old) the problem was resolved. The rears must have been transmitting the vibration through the brake fluid causing the front wheels and steering wheel to judder. May be worth checking the rears out first.
Old 07-09-2007, 07:34 PM   #4
v8shadow
Default cheers
cheer for your info will give the advice ago
cheers. T
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
Wilwood MKIII Rear brake kit ARZ Arizona Performance 0 03-16-2007 07:46 AM
87 supra brake lights ministrytrav MKIII Supra 4 11-23-2005 08:53 PM
