Old 07-14-2007, 03:17 AM   #1
77celi
77celi is on a distinguished road
Default What year
How can I find out what year my motor is? I did a search found a forum that said it was the 10th digit in the vin next to the oil filter. I only have 9 digits they are 7m0159012
77celi is offline   Reply With Quote
Old 07-14-2007, 10:03 AM   #2
Bill UK
AEM EMS
Bill UK's Avatar
That’s the engine number, the VIN number is on the label attached to the bulkhead. It should be something like this JT1LBMA70 0147428 Not easy to find the YOM from the engine number, if you send me your VIN number I will be able to tell you the YOM.
Old 07-14-2007, 10:10 PM   #3
j3pz
you cant tell from the engine. you would have to find the car the engine came out of
Old 07-15-2007, 12:49 AM   #4
77celi
I got the motor from Foreign Engines. They don't know the exact year. I told them I need a motor for a 87 supra n/a
Old 07-15-2007, 03:19 AM   #5
77celi
Where is the number located? I looked all over the block and could not find anyother number.
Old 07-15-2007, 05:37 AM   #6
plaaya69
plaaya69's Avatar
plaaya69 is on a distinguished road
I also needed to know this info but I looked around for a long time and I found out that you cant tell the year with the motor you must need to know the vin from the car with the motor.
1987 Toyota Supra Turbo-burgundy exterior w/gray interior+1987 Toyota Supra(N/A) light brown top,dark brown bottom w/light brown interior.
plaaya69 is offline   Reply With Quote
Old 07-15-2007, 07:56 PM   #7
77celi
I have no way of knowing what car it came out of. Is there a year to year difference? I have heard that the 86.5-88 and the 89-92 are the same. What is the difference between the two?
Old 07-15-2007, 08:49 PM   #8
Supra2NR
Supra2NR's Avatar
The 88+ 7m motors uses the true 7m crank
While the pre 88 motors uses a 6m crank
So I've heard
Somebody cement this claim for me
Old 07-16-2007, 01:57 AM   #9
77celi
So there is no easy way of telling what year it is?
Old 07-16-2007, 03:06 PM   #10
Supra2NR
Supra2NR's Avatar
im on my second supra
and went thru three motors already
never bothered me what year they were
although you can tell if its usdm or jdm
but as long as they run good, the year shouldnt matter
Year to Year MGE Swap changes Mr.Bojangles MKIII Supra 6 01-10-2008 07:44 PM
Im very interested in buying a mkIII next year... vixen_1505 Non-Generation Specific Questions 0 07-09-2007 02:44 AM
Best supra YEAR ?? HEMAN MKIII Supra 5 08-11-2006 06:17 PM
20 year reunion ddmcse MKIII Supra 7 04-12-2006 03:50 AM
Which Year Mkiv Would You Buy? prolude MKIV Supra 7 10-12-2005 01:24 PM
