Old 07-19-2007, 03:47 PM   #1
finaltable
finaltable is on a distinguished road
Default Mk III Antenna,rear wiper motor, rear lock non-functional. Advice needed
I'm starting to work on the few things that need fixing on my car. These include the heater, the rear wiper, the power antenna and the rear hatch lock mechanism. The heater is beyond my capabilities and the antenna seems tough to get to so I am starting with the wiper motor.
I think that the controls on the steering column still work because I can still squirt water out of the fluid jets on the back. My next culprit is the motor itself. Is there any way I can apply power to it directly to see if it is in fact functional? It has been suggested by someone to make a couple of really long wires with alligator clips on the ends that I can attach to the battery. Is this a bad idea? If it isn't, can I just hook up one to the wiring contacts and touch the other one to get it to operate or do that have to be done in a particular way?
Since I'll be back there with tools anyway, any advice on the antenna or hatch? I've removed every nut that appears to hold the exterior panel over the latch and it simply won't come off to expose the lock. Is my assessment correct that I am going to take apart most of the passenger side rear panel to fix the antenna?
Thanks.
Current ride: Not a Supra :-(
finaltable is offline   Reply With Quote
Old 07-19-2007, 06:07 PM   #2
dannydavi
dannydavi's Avatar
yeah you have to take off the back seat rests and the interior by the back seats, pretty simple. And once you do that everything will be easier to get to.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 07-19-2007, 06:35 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Antenna link. http://www.toyota-supra.info/forums/...ead.php?t=7242
Old 07-20-2007, 06:25 AM   #4
plaaya69
plaaya69's Avatar
plaaya69 is on a distinguished road
On the heater, do you have the heater valve vsv bypassed? that might be your problem because the vsv does not last long on the heater valve
1987 Toyota Supra Turbo-burgundy exterior w/gray interior+1987 Toyota Supra(N/A) light brown top,dark brown bottom w/light brown interior.
plaaya69 is offline   Reply With Quote
Old 07-20-2007, 01:06 PM   #5
finaltable
I don't even understand what that means. I guess I'll have to learn.
Advice needed. Newbie looking to do a restoration right finaltable MKIII Supra 6 03-02-2007 02:57 AM
