Old 05-25-2005, 01:55 AM   #1
Black 5spd
Black 5spd is on a distinguished road
i have just changed the oil in my 1986.5 supra i put in 4 quarts of oil but it was right in the midle of the dip stik but today i checked the oil and it is at the add mark.
what should be the oil presure at idle???
how high should iut go at 3000-3500 rpm???
new to supras so i need to know this stuff, aske anything about beemers though.
Black 5spd is offline   Reply With Quote
Old 05-25-2005, 11:11 AM   #2
KingDiamond
KingDiamond is on a distinguished road
idle i believe it is 4.6 psi
and around 3000 to 3500 it should be between 36 and 72 psi
your probably burning some oil, rings are worn, not a biggie really car probably still has a lot of power like mine does even though she burns oil.
KingDiamond is offline   Reply With Quote
Old 05-26-2005, 07:59 AM   #3
monkihead
SP58GT
monkihead's Avatar
whoa 4.6!?! thats way too low. check to see if shes leakin it any where first. if shes burning it bad, you should see a faint blue color come out of the tail pipe once in a while.
monique- better off dead
Old 05-26-2005, 09:32 AM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
1. kingdiamond is correct, idle is 4.6psi.. we are high flow low pressure systems
2. if he was burning it bad it would be way more than a faint smoke now and then :P
i would say it has a leak, possibly rear or front crank seals
Pics of my build.
Do a diagnostic first!
Old 05-26-2005, 11:41 AM   #5
KingDiamond
don't under estimate the little information you can find in the owners manual
Old 05-27-2005, 01:27 AM   #6
jza80 Supra C-I TT
jza80 Supra C-I TT is on a distinguished road
what is psi (if it is dumb could u still answer please. im only 15)?
[img]http://rds.yahoo.com/S=96062883/K=supra+logo/v=2/SID=w/TID=I001_70/l=IVS/SIG=127fv51d7/EXP=1118546922/*-http%3A//www.supra.racingteam.kessler.com.pl/logo.jpg[/img]
<span style='color:green'>300 horsepower is 299 too much for any camaro</span>
MKIV POWER *cough* suprra _girl *cough cough*
jza80 Supra C-I TT is offline   Reply With Quote
Old 05-27-2005, 01:30 AM   #7
KingDiamond
PSI = Pounds per Square Inch
Never a dumb question, better to ask and learn rather then try and fool people into believing you know more then you actually do. The more questions you ask the more you will learn.
Old 05-27-2005, 01:42 AM   #8
jza80 Supra C-I TT
thx kingdiamond. what does pounds per Square Inch usually refer to?
Old 05-27-2005, 01:47 AM   #9
KingDiamond
If your asking the whole mathematical explaination as to how they figure out exactly, and how they came up with the measurement, i have no idea, but now that you mention it, it would be something nice to know. But as far as if your asking where else they use PSI, your fuel pressure, pressure in transmission, stuff like that.
Old 05-27-2005, 01:49 AM   #10
jza80 Supra C-I TT
so its basically everything about fuel.
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
