Old 06-02-2005, 11:25 PM   #31
monkihead
monkihead's Avatar
Originally posted by jza80 Supra C-I TT@Jun 1 2005, 10:05 PM
what are cams exactly? is it older versions of pistons? whats the difference between a twin turbo and a twin cam?
cams are camshafts that open and close the valves. twin cams means 2 camshafts.
twin turbo'd are 2 turbos. any toyota engine(to my knowledge) with a "g" is a twin cam engine.
ie- 5mge<---6cyl, twin camshaft, electronic fuel injection
4afe<-----4cyl, economy head, electronic fuel injection
3sgte<----4cyl, twin cam, turbo, electronic fuel injection
monique- better off dead
Old 06-08-2005, 12:17 AM   #32
Here is a link that explains what PSI is, but is complicated.
http://www.answers.com/topic/pound-force-p...per-square-inch
Basically it is a measurement of pressure applied to a 1" square suface, by whatever substance, generally air (a gas), or liquid.
Thus, there is pressure (psi) in these systems: turbo boost, engine oil, fuel, automatic trans oil, radiator, power steering, brake, tires, and (on some cars, air shocks).
And remember this, pressure in a system can be dangerous if there is a problem, or opening it up, and most systems under pressure are hot.
Old 06-08-2005, 12:22 AM   #33
jza80 Supra C-I TT
jza80 Supra C-I TT is on a distinguished road
thank u very much. i havent read the link yet but i'm sure its going to help alot. if u know anything else there is to know about a supra could u guys feed me the information?
[img]http://rds.yahoo.com/S=96062883/K=supra+logo/v=2/SID=w/TID=I001_70/l=IVS/SIG=127fv51d7/EXP=1118546922/*-http%3A//www.supra.racingteam.kessler.com.pl/logo.jpg[/img]
<span style='color:green'>300 horsepower is 299 too much for any camaro</span>
MKIV POWER *cough* suprra _girl *cough cough*
jza80 Supra C-I TT is offline   Reply With Quote
